MMOexp MLB 25: Don't be afraid to attempt steals with fast players
Good base running can make the difference between a close win and a blowout. Aggressive baserunning, like taking extra bases or stealing, can catch the defense off guard and put pressure on MLB 25 Stubs your opponent.
Why it matters: A good base runner can move into scoring position quickly, while poor base running decisions can result in easy outs.
Tip: Don't be afraid to attempt steals with fast players, but make sure you're reading the pitcher's timing. Use the "lead off" mechanic to take extra steps, and know when to hold off for a better opportunity.
Learn to Use the Shift to Your Advantage
The shift can be a powerful defensive tool when used correctly, especially against pull-heavy batters. By shifting your fielders to the right or left, you can increase your chances of catching a ball in play.
Why it matters: Shifting gives your defense the opportunity to take away key hits and potentially save runs. But if you shift too aggressively, you risk leaving gaps in the defense that can be exploited by a smart batter.
Tip: Use the shift when you know a batter frequently pulls the ball to one side. You can also try the shift on high-average batters to force them into hitting into a tougher defensive position.
Use Advanced Fielding Techniques
Good fielding can save runs and prevent costly mistakes. While basic fielding is enough for most situations, using advanced techniques like the perfect throw mechanic can be the difference between a runner being safe or out.
Why it matters: The more accurate and timely your throws are, the fewer mistakes you'll make, which means fewer runs allowed and more outs recorded.
Tip: Practice using the perfect throw mechanic for better accuracy and timing, especially when trying to get runners out at home plate or at third base.
Take Advantage of Hot and Cold Streaks
In MLB The Show 25, players can go through hot and cold streaks. A batter on a hot streak will hit the ball more consistently, while a batter on a cold streak may struggle to make contact. Understanding when your players are hot or cold can help you manage your lineup better.
Why it matters: A player on a hot streak can be a key weapon, while a player on a cold streak may need a break or a change in position in MLB The Show Stubs the lineup.
Tip: Keep an eye on your players' hot and cold streaks and make adjustments to your lineup as needed. Don't be afraid to sit a slumping player for a few games to let them break out of the cold streak.
