MMOexp-COD BO7: How to Drop a Nuke with the C9 SMG
The release of Call of Duty: Black Ops 7 is bringing some serious competition to the FPS landscape, and as always, the key to victory lies in building the right loadouts. If you want to secure your first nuke or simply dominate the leaderboards, you need to know which weapons and attachments stand out in the current meta.
Below, we're breaking down the top five meta loadouts in Black Ops 7, including Gunfighter setups (8 attachments) and streamlined 5-attachment class builds for players who prefer more perks or streak flexibility. Whether you're new to the game or grinding ranked modes Call of Duty Black Ops 7 Bot Lobbies, these builds will give you a huge edge.
1. XM4-The All-Rounder Assault Rifle
The XM4 continues to be a staple pick, dominating both Black Ops 7 multiplayer and Warzone thanks to its excellent accuracy, low recoil, and high damage. It's versatile enough for any map and is perfect for securing streaks.
XM4 Gunfighter Loadout (8 Attachments):
Optic: Kepler Microlex-A clean, minimalist sight for maximum clarity.
Muzzle: Suppressor-Keeps you off the minimap without hurting accuracy.
Barrel: Reinforced Barrel-Improves damage range and bullet velocity.
Underbarrel: G-Grip-Enhances recoil stabilization and hipfire accuracy.
Magazine: Extended Mag 3-A massive 100 rounds, turning your AR into a hybrid LMG.
Rear Grip: Commander Grip-Boosts ADS speed and sprint-to-fire speed.
Stock: Infiltrator Stock-Improves aim-walking movement speed.
Fire Mods: Recoil Springs-Smooths out horizontal and vertical recoil patterns.
With this setup, the XM4 becomes a laser beam with incredible magazine capacity, allowing you to shred through multiple enemies without reloading.
XM4 5-Attachment Build:
Remove Extended Mag 3, Infiltrator Stock, and Recoil Springs.
This lighter version has less ammo and slightly reduced mobility, but it still maintains solid accuracy and a fast time-to-kill (TTK).
2. C9-The SMG King
If you're all about fast-paced, close-range combat, the C9 SMG is your best bet. It has a lightning-fast TTK, excellent mobility, and surprising versatility at medium ranges.
C9 Gunfighter Loadout (8 Attachments):
Optic: Kepler Microflex-Helps with visibility for slightly longer engagements.
Muzzle: Suppressor-Essential for staying off radar in close-quarter battles.
Barrel: Long Barrel-Maximizes damage range.
Underbarrel: G-Grip-Provides recoil control and better handling.
Magazine: 10mm Auto 30-Round Mags-Increases bullet velocity and damage.
Rear Grip: Ergonomic Grip-Boosts slide-to-fire, dive-to-fire, and ADS speeds.
Stock: Infiltrator Stock-Enhances aim-walking speed.
Fire Mods: Recoil Springs-Reduces recoil for tight spray control.
C9 5-Attachment Build:
Remove Kepler Microflex, Infiltrator Stock, and Recoil Springs.
You'll still have excellent mobility and TTK, but aim for burst-fire at long distances.
3. AK74-The Underrated Beast
The AK74 AR is criminally underrated but is an absolute powerhouse post-update. It has great stopping power and feels incredibly rewarding in skilled hands.
AK74 Gunfighter Loadout (8 Attachments):
Optic: Kepler Microflex or V Reflex (personal preference).
Muzzle: Compensator-Controls vertical recoil.
Barrel: Long Barrel-Boosts damage range for improved mid-range dominance.
Underbarrel: G-Grip-The best choice for recoil management.
Magazine: Extended Mag 1-Provides 40 rounds without slowing weapon handling.
Rear Grip: Commander Grip-Improves ADS speed and responsiveness.
Stock: Infiltrator Stock-Enables faster aim-walking speed.
Fire Mods: Rapid Fire-Speeds up the fire rate without excessive recoil penalties.
The AK74 can still achieve three-shot headshot kills with this setup, making it deadly in skilled hands.
AK74 5-Attachment Build:
Remove V Reflex, Extended Mag 1, and Infiltrator Stock.
The AK74 remains lethal and retains solid recoil control, even with fewer attachments.
4. KSV-The Run-and-Gun SMG
The KSV is a high-speed SMG perfect for aggressive players who like to flank and stay constantly on the move. It has a slightly higher recoil profile, but the right attachments make it very manageable.
KSV Gunfighter Loadout (8 Attachments):
Optic: Kepler Microflex or V Reflex-If you dislike the iron sights.
Muzzle: Compensator-Mandatory to handle vertical recoil.
Barrel: Reinforced Barrel-Improves both damage range and bullet velocity.
Underbarrel: Ranger Foregrip-Increases horizontal recoil control and sprinting stability.
Magazine: Extended Mag 2-Provides 50 rounds to sustain gunfights.
Rear Grip: Ergonomic Grip-Essential for improving ADS and sprint-to-fire speeds.
Stock: Infiltrator Stock or Balanced Stock-For faster aim-walking movement.
Fire Mods: Recoil Springs-Keeps the KSV's spray pattern tight.KSV 5-Attachment Build:
Even with fewer attachments, this SMG still dominates close-quarters combat.
5. FFAR1-The Hybrid AR/SMG
The FFAR1 combines the handling of an SMG with the range and stopping power of an AR. It's one of the fastest-killing rifles in Black Ops 7, especially with the right build.
FFAR1 Gunfighter Loadout (8 Attachments):
Optic: Kepler Microflex or V Reflex.
Muzzle: Compensator-Controls its naturally high recoil.
Barrel: Long Barrel-Extends range and improves TTK.
Underbarrel: G-Grip-Greatly improves handling and recoil control.
Magazine: Extended Mag 2-60 rounds to handle multiple enemies.
Rear Grip: Commander Grip-For faster ADS and sprint-to-fire speeds.
Stock: Infiltrator Pad-Maximizes aim-walking movement.
Fire Mods: Recoil Springs-Stabilizes this high-fire-rate AR.
FFAR1 5-Attachment Build:
Remove Extended Mag 2, Infiltrator Pad, and Recoil Springs.
The recoil increases slightly, but the FFAR1 remains one of the fastest-killing ARs in the game.
Perks, Secondary Weapons, and Equipment
All these loadouts pair well with a Strider 22 (3-round burst mod) as a secondary. It's a reliable fallback weapon when your primary runs dry.
Recommended Equipment & Perks:
Lethal: Blast Trap
Tactical: Stim Shot
Field Upgrade: Assault Pack
Perks: Flak Jacket, Dispatcher, and Bankroll.
If you're using 8-attachment Gunfighter builds, this perk combo is ideal. Otherwise, run Perk Greed or High Roller.
Scorestreak Strategy for Nukes
To maximize your streak potential:
UAV-Essential for map awareness.
Grim Reaper-Great for multi-kills that count toward your nuke streak.
War Machine-Another killstreak that adds to your nuke counter CoD Black Ops 7 Bot Lobbies.
HARP (High-Altitude Recon Plane)-Gives you constant enemy tracking.
The synergy of Grim Reaper + War Machine allows you to rack up streaks fast. For example, starting at 10 gun kills, you can easily chain streaks to hit 30 kills with far less risk.
Final Thoughts
These five meta loadouts-XM4, C9, AK74, KSV, and FFAR1-are the strongest weapon builds in Black Ops 7's current meta. Whether you're running Gunfighter with 8 attachments or a leaner 5-attachment build, you'll find these setups cover every playstyle: from mid-range dominance to close-quarters aggression.
