Want to farm over 750,000 Stubs in just a few days in MLB The Show 26? Still stuck grinding full games with low rewards and slow efficiency? The truth is simple-the key isn't playing more, it's playing smarter. In Diamond Quest (Summer route), your roadmap decisions and bunting strategy matter far more than raw hitting skill. This guide explains how to farm Stubs efficiently using a dual-stadium route, a bunt-focused lineup, and strict tempo control, letting you consistently earn 50,000+ Stubs per run. If you want a faster start, MLB The Show 26 Stubs also provide an important foundation for building an efficient squad.
Bunts Are the Ultimate "Free-to-Play" Money-Making Weapon
In Diamond Quest, most players still rely on power hitting and big swings. One mistake can instantly kill a run and waste valuable time. My approach is completely different: I use bunts exclusively.
Zero barrier: You don't need elite hitting mechanics or expensive cards-just pressing Triangle is enough.
High efficiency: With 99-speed players, bunts turn into chaos on the infield and easy base advancement.
Minimal downside: Even with negative perks like reduced bunt or speed, the overall impact is still negligible in real runs.
The goal is not flashy baseball-it's pure efficiency and maximum Stubs per minute.
The "Snake Route" Dual-Stadium Method
Route planning is more important than mechanics. The core strategy is always targeting two stadiums per run: the Philadelphia Phillies and the New York Yankees.
Start with the Phillies: Move directly from your starting point toward the Phillies stadium and build your route around early objectives.
Loop toward the Yankees: On the way back, step on as many challenge tiles as possible to boost reward chances from around 70% to nearly 90%.
Clear in order: Finish Phillies first, then reset your pathing, then push toward Yankees for a full optimized run cycle.
Beginner tip: If your win rate is unstable, stick to a single stadium first before switching to the full dual-route system.
Budget Bunt Lineup
You don't need to spend MLB The Show 26 Stubs to assemble this roster. This "budget bunt squad" is already enough to execute the strategy:
Core starters: Bryce Tom (WBC), Jimmy Rollins (City Connect), Hank Thompson, Willie McGee-all excellent bunt-control players.
Cheap alternatives: Victor Scott II, Tony Gwynn, Lou Brock, Barry Larkin.
Upgrade priority: Max speed to 99 first, then invest remaining points into defense for stability.
With high speed, even weak bunts often become infield hits.
Three Core In-Game Techniques
Bunt timing: Use the hold-release method-hold Triangle during pitch delivery, release early for bad pitches and slightly later for strikes.
Base running: Tap L1 once to lead off; avoid double inputs. Use L2 for steals and stick control for safe sliding.
Pitching simplified: Use your fifth starter and focus on low-outside pitches. If inconsistent, switch to Darren O'Day or Tyler Rogers for safer control.
When to Sell Your Cards Matters
Patient approach: Hold cards and sell during event spikes such as Legend collections or Stub promotions for maximum value.
Fast approach: If you need cheap MLB The Show 26 Stubs quickly, list items slightly under market price (about 5 Stubs lower) to ensure fast sales.
Diamond Quest also helps complete Team Affinity missions, boosting XP and PXP progression efficiently, especially during Double XP events.
Who Is This Guide For?
Free-to-play/low-spend players: Build wealth without spending money.
Average grinders: Simple mechanics with consistent rewards.
Busy players: 3-hour daily sessions can build a full economy in a few days.
Pro Tip
Spend 10 minutes in custom practice using PCA settings on GOAT difficulty. Focus only on bunt placement into open infield gaps. Once consistent, your success rate and Stub income will increase dramatically.
Key Benefits by Player Type
New players: Easy entry-level farming system without expensive cards.
Veterans: Optimized route that reduces grind time significantly.
Collectors: Fast XP and Team Affinity progression.
All players: Stable, repeatable, low-risk Diamond Quest farming loop.
