MMOexp:750K Stubs in 3 Days? MLB The Show 26's Bunt-Only Diamond Quest Method Explained
Postat: 24 jun 2026, 10:54
Want to farm over 750,000 Stubs in just a few days in MLB The Show 26? Still grinding matches with low returns and slow efficiency? The real key isn't "playing more"-it's playing the right mode. In Diamond Quest (Summer route), the roadmap and bunting strategy are what truly matter. This guide breaks down how to efficiently farm Stubs using a dual-stadium route, bunting-focused lineup, and tempo control, allowing you to earn over 50,000 Stubs per run. If you want a faster start, MLB The Show 26 Stubs also provide an important foundation for building an efficient squad.
Bunts Are the Ultimate "Free-to-Play" Money-Making Weapon
In Diamond Quest, many players still rely on base hits and home runs. One mistake can ruin the run, wasting both time and rewards. My approach is completely different: I use bunts exclusively.
Zero barrier: You don't need elite hitting skills or top-tier cards-just knowing how to press Triangle is enough.
High efficiency: With 99-speed runners, bunts create infield chaos and easy base advancement.
Negligible debuffs: Even with negative perks like reduced bunt or speed, the impact is minimal in practice.
The goal isn't beautiful baseball-it's maximum Stubs in minimum time.
The "Snake Route" Dual-Stadium Method
Route planning matters more than mechanics. My core strategy is to always target two stadiums per run: the Philadelphia Phillies and the New York Yankees.
Start with the Phillies: From the starting point, head directly toward the Phillies stadium and build your route around it.
Loop toward the Yankees: On the return path, step on as many challenge tiles as possible-these increase reward probability from around 70% to nearly 90%.
Clear sequentially: Finish the Phillies first, then backtrack (without triggering new challenges), and then take on the Yankees. After both stadiums, reward probability is nearly maxed out.
Beginner tip: If you're unstable, start with only one high-value stadium. Once comfortable, switch to the dual-stadium route.
Budget Bunt Lineup
You don't need to spend MLB The Show 26 Stubs to build this roster. This "budget bunt squad" is more than enough:
Core starters: Bryce Tom (WBC), Jimmy Rollins (City Connect), Hank Thompson, Willie McGee-all with smooth bunt control.
Cheap alternatives: Victor Scott II, Tony Gwynn, Lou Brock, Barry Larkin.
Upgrade priority: Push all players to 99 speed first, then invest in defense.
With enough speed, even poorly placed bunts can turn into infield singles.
Three Core In-Game Techniques
Bunt timing: Use the "hold-release" method. Hold Triangle as the pitch comes in, then release early for bad pitches and slightly later for strikes. On GOAT difficulty, the AI throws plenty of bad pitches-take the free walks.
Base running: After reaching base, only tap L1 once to lead off. Never double tap. Use L2 for steals and flick the right stick during slides to avoid tags.
Pitching simplified: Use your fifth starter and spam low/outside pitches. If unstable, switch to Darren O'Day or Tyler Rogers and rely on outside sliders.
When to Sell Your Cards Matters
Patient players: Hold your cards and sell during official events (Legend collections or Stub promotions) when prices spike.
Fast sellers: If you need cheap MLB 26 Stubs quickly, list your items 5 Stubs below the lowest price-they usually sell instantly.
Playing Diamond Quest also helps complete Team Affinity missions, boosting XP and PXP quickly. Double XP weekends make efficiency even higher.
Who Is This Guide For?
Free-to-play/low-spend players: Earn Stubs without paying.
Average-skilled grinders: Simple bunting gets the job done.
Busy players (students or workers): 3 hours a day can build your entire economy in 4 days.
Pro Tip
Before starting, spend 10 minutes in custom practice using PCA settings. Set difficulty to GOAT and practice bunting into open infield gaps. Once you can consistently place bunts, your success rate skyrockets.
Key Benefits by Player Type
New players: Simple, stable Stub farming without needing top-tier cards.
Veterans: Optimized farming route that drastically reduces grind time.
Collectors: Massive XP and progression gains for collections and Team Affinity.
All players: Safe, stable, and consistent Diamond Quest farming strategy.
Budget Bunt Lineup
Pro Tip
