ARC Raiders weekly quests are refreshed-search probes, locate assessors, deliver couriers. Sounds simple, right? But the moment you drop in, you're getting chased across the map by drones? Don't panic. Getting a 3-star clear isn't that hard-the key comes down to three things: find black smoke, prioritize triple-search probes, and don't fight bombers head-on. This guide breaks down a real gameplay route step by step, showing every decision in detail. Follow this approach and you can finish in about ten minutes. As for good ARC Raiders Items, make sure your loadout is properly prepared-it helps you loot faster and move more safely.
Why Blue Gate Is the Best Starting Point: Vision = Survival
I chose Blue Gate as my starting map. Other maps work, but Blue Gate stands out because of its open sightlines-you can spot black smoke and enemies from far away. Instead of running into danger blindly, you can plan your route in advance. The time you save here often equals one extra probe cleared.
Black Smoke = Points: Spot It, Mark It, Go
Crashed probes always emit black smoke, and that is your most reliable indicator. If there's smoke, there are points.
First thing after landing: scan the horizon. Once you see smoke, mark it and plan the shortest possible route.
There are two probe types:
Single-search probes: ~250-300 points per interaction, small but steady value
Triple-search probes: three interaction points, effectively triple rewards-always prioritize these
Route Breakdown: Triple Probes Are the Real Game-Changer
I started near the bomber zone and picked up a few single probes along the way. Slowly, the score climbed.
Then I found a triple-search probe in the central area-after completing all three interactions, my score jumped from around 1700 to over 2500 instantly, pushing me from one star to two stars in a single moment.
If you want smoother runs and better survival in high-pressure situations, ARCR Items can help stabilize your loadout and improve efficiency.
Endgame at Ancient Fort: One Last Probe, One Last Risk
I was missing just one probe for 3 stars. Near Ancient Fort, I spotted a landing probe-but it was under heavy pressure. Bombers were patrolling, drones everywhere, and I only had about 8 minutes left.
Rushing in would have been suicide. So I waited. I used rocks as cover, watched bomber sightlines, and moved only when a safe window opened. Once the path cleared, I broke the probe and completed all three interactions.
3 stars secured.
Don't Fight What Doesn't Need Fighting
Drones and bombers will constantly try to slow you down. The rule is simple: ignore them unless they block your path to a probe.
Every second spent fighting is time stolen from scoring.
Core Strategy Summary: Efficiency Over Combat
Black smoke is your only reliable tracking signal
Triple probes are always top priority
Skip unnecessary fights completely
Use cover to wait for safe openings
Time management is more important than combat
Who This Guide Is For
Weekly mission strugglers: learn a complete, repeatable 3-star route
Players tired of drone pressure: know when to fight and when to ignore
Efficiency grinders: maximize score per minute through prioritization
Quick Tips
Scan for black smoke immediately after landing
Always prioritize triple-search probes
Avoid unnecessary combat-it slows progression
Blue Gate offers the safest and clearest visibility for routing
Core Value Summary
New players: a fully repeatable 3-star route
Struggling players: learn how to avoid damage and farm safely
Efficiency players: master probe priority and time control
