The first time you open the autoshow in Forza Horizon 6, it's hard not to laugh a bit. Everything you want costs a silly amount, and your garage looks pretty sad next to those Ferraris, Paganis, and track toys. Still, you don't need to panic or chase every race on the map at once FH6 Credits. A steady mix of exploration, smarter difficulty settings, and a few well-timed sales can build your balance fast, even before you think about extra FH6 Credits for topping up your spending money.
Start by driving, not grinding
New players often miss the easiest cash because they're too busy hunting the fastest race. Just roam. Open roads, find beauty spots, smash boards, tick off landmarks, and clear the map bit by bit. It doesn't feel like farming, which is the nice part, but the rewards stack up. By the time you've done a proper sweep, you can walk away with a few million credits and a better feel for the new roads. You'll also learn which corners bite, where the long straights are, and which cars actually suit your hands.
Turn up the challenge when you're ready
Assists are useful at the start. No shame in that. But once you're comfortable, start switching a few off. Traction control, stability control, braking line, all of it affects your bonus. You don't have to jump straight into the deep end either. Move the AI up one step, run a couple of shorter events, then push again. Expert or Pro difficulty can make normal racing feel much more worthwhile. The races become messier, sure, but they pay better, and you'll improve faster because the game stops saving every bad throttle input.
Use long races carefully
Endurance events are where a lot of players make serious money. The Colossus is usually the one people talk about, especially in convoys, because online runs can pay much better than lonely solo laps. A Forza Edition car helps a lot here. Something with a credit or XP boost turns a long session into a proper earner. People often use stable builds rather than wild top-speed tunes, because crashing every few minutes ruins the point. If you're running a long setup, keep the controller connected, check your assists, and don't leave the car bouncing off walls for half the race.
Cheap cars can carry your early game
You don't need a hypercar to start making money. The Nissan Silvia S13 is a good example. It's cheap, easy to control, and works well on tighter time attack routes once you give it a sensible tune. When Legend Island opens up, shift some of your farming there. The lap payouts are better than many early circuits, and the races are short enough that you won't get bored out of your skull. Keep your garage simple at first. Upgrade cars you'll actually use, not every shiny thing that pops up after a wheelspin.
Play the market, then spend smart
The Festival Playlist is where patient players quietly get rich. Grab limited cars when they're available, then hold them for a little while. Once they disappear from rewards, demand usually climbs, and the Auction House can get very generous buy cheap FH6 Credits. Property matters too. If Mountain Lodge is available in your save, buy it early for the permanent credit boost. It won't feel huge after one race, but over dozens of sessions it's free money. And if you're short before a rare auction, some players choose to buy cheap FH6 Credits so they don't miss the car they've been waiting on.
