Re: Ett eller två backljus?
It's common for some automobiles to have only one reverse light working. In the case of your Niro Hybrid 2020, if Kia states that it's designed to have just one reverse light on (the right side), it aligns with their specifications. Car works often have specific configurations for lighting. If you need further clarification or have concerns, contacting Kia's customer support or consulting your vehicle's manual can provide more insights. Best Expository essay writing Help can assist in explaining technical points like these completely.
elof skrev: 18 apr 2020, 01:21 Jag råkade se att när jag lägger i backen på min Niro Hybrid 2020 så lyser bara ett backljus (det på höger sida).
Kia åf säger att det ska vara så. Stämmer det?
Jag upptäckte samma sak som du på min Eniro EV 2023, varpå jag ringde verkstaden som sa' att det bara är en enda backljuslampa som skall lysa :-/
Återgå till "Niro"
